When do you use Silicone spray as opposed to oil or an oil based spray? (Or T-9)
I have a growing larder full of cans, bottle and tubes...
Mark
Mark
The short answer is that my slugs only touch the aft face of the mast and the aft face of the slot. They can't reach the back ( Forward face) of the slot.The problem is that the bearing surface of the slugs is the inside (forward facing) part of the channel extrusion. This surface is very hard to clean, and does not get washed by rain so who knows what sort of crud sticks to the aluminum... and causes friction. Friction-less slides they may be but I have found that some sort of lubricant sprayed on the slugs makes them move easier. YMMY.
If you are frequently raising, lowering and reefing there may be enough movement to "polish" as you say... I don't think that this is what would happen. The groove is like any surface on the boat which is exposed to air born "stuff" constantly.. including salt which cakes up. And unless your mast protected in the winter it gets not "slide polishing" for months on end. Sure you don't want to add something to trap the stuff... so find some other lubricant that doesn't add to the problem.The short answer is that my slugs only touch the aft face of the mast and the aft face of the slot. They can't reach the back ( Forward face) of the slot.
I use my boat a whole lot and all year round, so the contact points on the slot stays polished.
Adding lube, provides a sticky material for gunk to stick to perhaps adding to the friction you are fighting with more lube.
This is an application for dry lube like the teflon spray Registereduser suggested.so find some other lubricant that doesn't add to the problem.
I do carry triflo and will switch to it for this use. Thanks!This is an application for dry lube like the teflon spray Registereduser suggested.
Mark
Absolutely! You could try Marine Formula by DeBond Corp. I once had a boat whose PO believed that hardware store silicone glue was the answer to everything on the boat. He was particularly fond of using it to re-bed through deck hardware. Of course everyplace he used it leaked water because silicone quickly gets too hard for that use. After some research I found out about Marine Formula and it effectively removed the old slippery silicone so the new, proper, bedding compound would stick. Life is now good.Silicone is hard to remove even with normal solvents.
Just for the record, I don't mean to suggest that what I do would work for everyone or anyone else. I may be an outlier because I do use my boat more than most folks. Except for the lockdown, and the year I stripped out all of the hardware in the cockpit and cabin top to paint the deck (both around 6 weeks) the longest that my boat hasn't left the slip has been 3 weeks. That 3 week period was the year the creek stayed frozen longer than usual. After 3 weeks, I was really Jonesing to get out sailing. I was so desperate that I had planned to get in the dinghy with an axe and cut a slice through the ice. Miraculously a crack in the ice appeared and the ice separated a boat width. (see picture below) The engine intake thu-hull was iced over so we put the intake hose in a bucket on the cabin sole, and filled it with another bucket, just long enough to motor through the slot. Coming home we sailed through the slot and into the slip without bothering to start the engine.If you are frequently raising, lowering and reefing there may be enough movement to "polish" as you say... I don't think that this is what would happen. The groove is like any surface on the boat which is exposed to air born "stuff" constantly.. including salt which cakes up. And unless your mast protected in the winter it gets not "slide polishing" for months on end. Sure you don't want to add something to trap the stuff... so find some other lubricant that doesn't add to the problem.
I also run a soaked (wd 40) rag up and down the slot with a halyard and dnhaul to clean it and YES it does come out quite filthy. Usually do this after winter storage.Just for the record, I don't mean to suggest that what I do would work for everyone or anyone else. I may be an outlier because I do use my boat more than most folks. Except for the lockdown, and the year I stripped out all of the hardware in the cockpit and cabin top to paint the deck (both around 6 weeks) the longest that my boat hasn't left the slip has been 3 weeks. That 3 week period was the year the creek stayed frozen longer than usual. After 3 weeks, I was really Jonesing to get out sailing. I was so desperate that I had planned to get in the dinghy with an axe and cut a slice through the ice. Miraculously a crack in the ice appeared and the ice separated a boat width. (see picture below) The engine intake thu-hull was iced over so we put the intake hose in a bucket on the cabin sole, and filled it with another bucket, just long enough to motor through the slot. Coming home we sailed through the slot and into the slip without bothering to start the engine.
When I used to use lubricant on the mast slot on a prior boat, I had built a slot cleaner that I could raise with a halyard. It would come out of the slot really full of gunk. Once I stopped lubing the slot, the slot cleaner came out clean so I stopped lubing the slot. I have never noticed that the friction became noticeably greater after I stopped lubing the slot.
Your mileage may vary.
