Home made jack stands - SailNet Community
 1Likes
post #1 of 27 Old 09-05-2009 Thread Starter
moonie5961's Avatar
x
moonie5961 is offline
post #2 of 27 Old 09-05-2009
Nice idea
Those look to be a pretty nifty idea.
I saved your images, (I hope that's ok). I have a Cal21 that I wanted to put up and I also have had trouble locating stands that are sutiable. Granted the 1,500 pounds I am planning to support doesn't compare to your needs, but if properly executed,
you should be ok. If you need to you can always make more. Noah's boat was held up with wood, no? Good luck and work with many hands. Jim B.
jimmyb514 is offline
post #3 of 27 Old 09-05-2009
One more thing
I can't see in the pictures but you might want to put squares of 3/4" plywood under the main load bearing timbers (maybe doubled up), to spread the load to help keep it from settling too much. Again, the best too you.
Jim B.
post #4 of 27 Old 09-05-2009
Wood is amazingly strong in compression, and those are built to take advantage of the strength. So I wouldn't worry about them failing. Being made of wolmanized wood, they could conceivably outlast metal ones
Depending on what the cost is, If you are any good with tools, it would be a simple thing to make up some custom stands using the threaded adjusters and plates on them, or buy your own:
Scaffold Swivel Jack - Scaffold, Scaffolding from ScaffoldMart
At six inch extension there's something like a 10,00lbs safe working load on them.
Ken.
merc2dogs is offline
post #5 of 27 Old 09-06-2009
xsboats's Avatar
The stands look like they will work fine. I would be concerned about one detail that can easily be dealt with. The poppets[swivel pads] appear to be mounted into the vertical standards by drilling a hole in the end of the p.t. 4x4. If this union were to be side-loaded, it could split through the side of the 4x4 due to the allignment with the grain pattern in the wood. I would wrap the end with epoxy and glass tape, hose clamps, or even a whipping with parachute cord to prevent this. The poppets appear to be from Brownell or Hostar stands. Being the most expensive part of commercial stands, you could easily duplicate the lower halves with pipe and angle economically at a local welding shop if you wanted all metal stands. Metal stands are available through West Marine.[I buy them on my Port Supply account regularly.] They can also be ordered from the Hostar website.[they build hydraulic boat trailers similar to Brownell's]
xsboats is offline
post #6 of 27 Old 09-06-2009
JimsCAL's Avatar
Defender sells Brownell jack stands. They also sell the screw swivel tops if you want to make the bottoms of wood.
JimsCAL is online now
post #7 of 27 Old 09-06-2009
Your insurance company would likely laugh at your claim if/when these failed.
I know us boaters can be cheap but, given the price of proper stands, some things are just not worth doing on the cheap.
k1vsk is offline
post #8 of 27 Old 09-06-2009
tager's Avatar
Why live by the insurance company? The insurance industry is a bunch of extortive bullshite anyway!
jeffzee likes this.
tager is offline
post #9 of 27 Old 09-06-2009
MarioG's Avatar
I don't see any thing wrong with that, my boat sat on a wood cradle for 15 yrs and not much more then those. I built the trailer with that very method and it works great. the sides seem to be more for stablelizing then to hold the weight
Heres Cradle P1010306 pictures from friends & fun photos on webshots
heres trailer P1010034 pictures from friends & fun photos on webshots
MarioG is offline
post #10 of 27 Old 09-06-2009
Coastal Traveler
nereussailor's Avatar
Send a message via Yahoo to nereussailor
Stands
I'm not sure that you're looking at thesame stands that I am, but the main supports that I see are more like 6x6's or even bigger. I don't see them breaking out. Stands are for side support, they keep the boat upright. They really don't hold the weight of the boat.
Dave
nereussailor is offline
The Cruising Life, by Jim Trefethen, and Cruising Financials Jim H Cruising & Liveaboard Forum 205 10-11-2010 07:07 PM
What educational books would you recommend Saasaan Learning to Sail 31 02-15-2007 01:08 PM
Stepping a deck mounted mast while on jack stands DanRudolph General Discussion (sailing related) 22 08-29-2006 03:34 PM
Finding Jack Stands Jerry Hammill Gear and Maintenance Articles 0 09-05-2002 08:00 PM
