Drive Belt For Autohelm 4000 - SailNet Community
post #1 of 16 Old 05-10-2008 Thread Starter
Does anyone know where we can get a drive belt for an autohelm 4000?
Thanks
becky52 is offline
post #2 of 16 Old 05-11-2008
Mikelivingstone's Avatar
Depends where u r based, usually belt kit is available from Autohelm/ raymarine dealers, kit also includes the tool required to open the unit for belt removal.
Mike
Mikelivingstone is offline
post #3 of 16 Old 07-14-2008
ST 4000 belt
do a search on sailnet it was posted first under Irwin and then under gear and maintenance.
wdtracey is offline
post #4 of 16 Old 07-21-2008
Becky,
I went through an exhaustive search a few months ago with no luck. Raymarine is of absolutely no help, they claim to have no more belts and the solution is to buy a new autopilot. The best alternative I could find was to have a belt fashioned from polyurethane with a Kevlar core (the original belt is poly w/steel core). There are a number of companies that will make these custom belts. Good luck, and a pox on Raymarine!
If you do find a place to order or make a belt, you have to know the specifics about the belt. Mine, off an Autohelm 4000, was an AT9-765. "AT" indicates the shape of the tooth profile, "9" indicates 9mm wide, and "765" indicates a circumference of 765 mm. Good luck, I hope you find one.
kvaavik is offline
post #5 of 16 Old 07-21-2008
thinking of this...
JSL3's Avatar
I was looking for the service manual the other day for the autohelm 4000 and I downloaded it. The part number is "D169" if that helps. I did a quick search on that part number and couldn't come up with anything other than what kvaavik said about Raymarine's solution being upgrade. A search for "autohelm 4000 parts" did turn up this site tho for a custom belt company Polytech Design Inc - Timing Belts & Pulleys. I couldn't find the part there, but you may try to call them??
Good luck.
~Jim
Ramble On
1986 Pearson 28-2
JSL3 is offline
post #6 of 16 Old 07-21-2008
From another thread on the same subject:
Originally Posted by wdtracey View Post
As anybody who has tried to replace the drive belt knows, Ratheon no longer sells the replacement belt. A belt is available from the supplier below at about $16.00. It has steel cords and is a neoprene
Poly Tech Design
26 West First St
Clifton N.J. 07011
800 859 7659
tHIER NUMBER IS: B10AT5/750 FPS
cOMPARABLE TO::
425 syncroflex AT 5/750
BTW, google is your friend...
sailingdog is offline
post #7 of 16 Old 07-21-2008
Where can I get a used wheeldrive unit?
My Autohelm ST4000 drive unit seems to have failed. I can't get the belt tension adjusted well enough to hold the clutch in the engaged position. Anybody know someone who wants to sell a working unit without the electronics?
Respite
rwberman is offline
post #8 of 16 Old 07-21-2008
Rwberman-
Really shouldn't hijack a thread... you'll get better results posting your own thread. Would also suggest you read the post in my signature.
post #9 of 16 Old 07-22-2008
beej67's Avatar
Might not be as much of a hijack as you think, Dog.
Respite
Berman, try replacing the belt first. The old Raytheon belts tended to stretch, a *lot*, and the Poly Tech belt listed above is shade smaller in diameter than the old Raytheon belts, so they have better holding tension. (I just bought a few)
Also, if the handle won't stay engaged, but your existing unit still works fine as long as the handle is held in place, then just tie a piece of shock cord around the drive and use that to hold the handle down. I know of quite a few people who've done that with their ST4000s, as did I for a couple years before I bought new belts as per above. Yeah, it's kinda ghetto, but what works, works.
If you haven't ever replaced a belt before, it's pretty easy. The front and back halves of the unit snap together, so you can snap them apart (gently) with a long screwdriver. You'll need to remove some screws on a housing to get at the belt, but it's a piece of cake.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #10 of 16 Old 07-22-2008
thinking of this...
JSL3's Avatar
I did a similar thing to solve this problem on my Autohelm 4000. The clutch lever wouldn't stay in the engaged position so I inserted a wide diameter rubber band between the clutch lever and the back of the drive unit. The little bit of friction that the rubber band introduced solved the problem. Agreed, it is a little ghetto, but it works so far.
Good luck.
~Jim
Ramble On
1986 Pearson 28-2
JSL3 is offline
Water Drive Mark Matthews Gear and Maintenance Articles 0 12-05-1999 07:00 PM
Water Drive Mark Matthews Cruising Articles 0 12-05-1999 07:00 PM
