through deck electrical - SailNet Community
post #1 of 13 Old 11-09-2007 Thread Starter
looking for some help locating a through deck waterproof electrical connector. i can find 2 wire connectors but i would really like to find a three (or four) wire connector so 2 circuits could be run up the mast for anchor light and steaming light.
jimmd is offline
post #2 of 13 Old 11-09-2007
West Marine has 4 wire through deck connectors for $17.95.
Just go to their web site or a local store. I put 2 on my S-2 9.2A last year when I rewired my mast.
SailorBiker is offline
post #3 of 13 Old 11-11-2007
This is how I did this on my boat. It works great, no leaks and it is easy to add wires later.
Deck view
Inside view
rhaley is offline
post #4 of 13 Old 11-12-2007
Thanks Rick. I thought of building some trim to enclose it, and I still may, but to be honest, I moved on to other projects and forgot about it.
Since it is in the head, occupants of said space tend to have other things on there mind while they are in there!
rhaley is offline
post #5 of 13 Old 11-12-2007
rhaley,
Very good looking job! Can you describe the conduit material and the thru-deck?
Thanks
Lmtx is offline
post #6 of 13 Old 11-12-2007
Catalina direct also has the connectors.
http://www.catalinadirect.com/index....category_id=32
Andyman is offline
post #7 of 13 Old 11-12-2007
Lmtx
At the deck level, it is a 1" SS thruhull. The piece of teak you see on the inside pic is a backing block that gave me just the right amount of threads above deck to tighten the lock nut and not have a lot of bare threads exposed. I cut the hole in the deck with a hole saw the next size bigger than required and then filled the hole with thickened epoxy. It cured for a few days and I redrilled in the center of the filled hole with the smaller hole saw, leaving a hole through the deck that completely isolated the deck core and laminate from the outside world. I coated the filling with polysulfide and installed.
The mast fitting is a 7/8" SS 45 degree pulpit base. A hole was drilled in the mast and then I rotated the base to find the best angle for the wire lead. Then I drilled and tapped the fastener holes in the mast for machine screws I cut to length such that when fully tightened, there was little to no thread protruding inside the mast. The base and screws were coated in Tef-Gel and mounted. The hose between the two fittings is white 1-1/8" saniation hose.
rhaley is offline
post #8 of 13 Old 11-12-2007
Seņor Member
TrueBlue's Avatar
I thought so . . . now that's thinking outside the box.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #9 of 13 Old 11-12-2007
Rick
Thanks again. I had fallen into the trap in the past of getting all the wires throught the deck by conventianal means, only to come up with something I wanted to add and not having a good way to get the wire through. Plus, this is one hole to keep bedded and sealed, which I find much easier and cheaper than induvidual connectors.
I started to fix some of the non-functional wiring when I bought the boat and got so frustrated with the original wiring that I just ripped it all out and started from scratch. I couldn't be happier with that decision.
Ryan
rhaley is offline
post #10 of 13 Old 11-12-2007
rhaley, Thanks for the info that is very helpful
Lmtx is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
